Disassembling viscous fan
  • Originally posted by MattF
    And 164 posts.
    69 of 'em are yours!
    • Originally posted by BUSHWHACKER
      You didn't really count them, did you? One plus point is that
      this thread is a veritable wealth of info regarding cooling system
      problems/modifications now.
      Just seen ferret's thread again, Charlie. Was that the hose that
      you mentioned crumbled? Nice work getting it sorted, BTW.
      Bet you must've been chuffed as punch when it fired up.
      Edit: Just figured out how you got the count Vince.
      • i was more suprised than anything else....
        havent tried a test drive yet, i'll let him do that tomorrow when he gets back from france..
        it's in me shed, mate.
        • page 18
          picking my rad up tomoz rang the guy today and he said it was in perfect running order. not the news i was hoping for
          so ive just ordered a pump from milners ( 68+vat from toyota)
          i can see in to the futre hear one surf up for sale
          • maybe this will make page 18
            • there again maybe not (you guys know how my luck runs)
              • Originally posted by john.sally
                Sod's law at work again. At least you managed page 18 with that one.
                When you fitted the ATF cooler, did you pop all fresh ATF fluid in? At least
                with the rad testing okay it is one less expense to worry about. Have you
                had chance to try a block and matrix flush yet? At least between the rad
                and pump that's two points eliminated. Just have to work on the others one
                by one now.
                • Just on another train of thinking, would a heater matrix rad be usable as
                  an extra ATF cooling rad inline with the existing one in the main rad, or
                  is the design or construction unsuitable? Still deciding whether to go down
                  the extra ATF cooler road, as of yet.
                  • John, another bit of info that may be useful for you:
                    http://toyotasurf.asn.au/forum/viewt...ht=viscous+fan
                    • Blimey! they do go on a bit. Just get the fan locked, works for me!
                        Me too, (upto just). However, half of John's initial problem is that
                        his viscous assembly didn't take kindly to being locked. BTW Vince,
                        that's one of the short threads. I disappeared into that site hours
                        ago to find that info. Gone crosseyed now.
                        Must admit, another piece of info I'm peeved about losing is regarding
                        a more slimline version of the viscous assembly that fits on the Surf.
                        Can remember seeing it, but have no idea where. Bugger.
                        • One for you Vince. Another thread to backup your bonnet vent theory.
                          http://toyotasurf.asn.au/forum/viewtopic.php?t=7031
                          Anybody have an opinion on whether the rear matrix would be any
                          good as an extra oil cooler, BTW?
                          • Quote from Oz runner.....
                            "But on the issue of scoops, I'm not familiar with your rules but you might want to check with your DOT beforehand as reverse facing scoops in WA are a big no no and you will get pinged . Forward facing scoops are not a problem.
                            Their reasoning being it could allow fluids to spray out over the windscreen if there is a probem etc."
                            Jeez! and I thought this country was petty!
                            One day, my bonnet will look like this....oh yes!
                            http://go.jeep-xj.info/HowtoBonnet.htm
                            • [QUOTE=MattF] However, half of John's initial problem is that
                              his viscous assembly didn't take kindly to being locked.QUOTE]
                              That's why I re-done mine, using the original holes around the edge of the coupling. It's now like having a normal fixed fan like they had in the days of black and white telly!
                                Yeah, I remember drooling over that one when I first saw it as well.
                                Shame there doesn't appear to be anything like this for the Surf.
