Well, spent half of today delving in scr*pyards.
Picked up a couple of
electric fans, which I think are suckers, not blowers, to try instead of the
viscous fan, if they work. Both are GM units with an alloy shroud and approx
14 or 15 inch blade diameter. First question. Both have a different blade type.
One is like a 5 blade version of the viscous fan, broad blades, whilst the
second one has several finer curved blades with a rim around the outer edge
of the blades joining them in a wheel type shape. Which of the two designs is
theoretically better at shifting air?
No problem with the ex-viscous fan by the way, but I'm just curious now as to
whether an electric fan is a viable replacement.
Off on a tangent, it's not until you look at other vehicles that you realise how
sturdily the Toyota's are constructed. Saw some Isuzu's, Cherokee's and some
RR's, I believe, and not one of them held a torch to the Surf for ruggedness.
Especially the Jeep. The build quality of those are pathetically bad.
