fuel pump relay black wire to fuel pump live
fuel pump earth to chassis
ignition 12v wire to black/yellow wire under dash
constant 12v wire to white wire under dash
crank wire to black/silver dot wire
ect wire to ect switch green/brown wire
overdrive wire to green/yellow wire in blue plug
reverse lights (blue wire?) to yellow wire in white plug
tacho wire to black/white wire on remaining surf plug
oil pressure switch wire to yellow wire on alternator
yellow alternator wire to yellow/blue plug wire
black/yellow alternator wire to red plug wire
white/blue alternator wire to white plug wire
I had to partially strip the loom to get the burned earth wire out and gave the relay boxes their own earth and are fine
