ok so I have the lexus partially striped, its currently sitting in the unit on some axle stands with front end removed ie- bumper, lights and radiators.
I plan to remove the ecu and wiring loom and other interior stuff shortly but I want to use the surfs original speedo instead of the lexus one, is this what the lexus 4th ecu plug is for and will it need modifying?
1994 ls400 in half gold, half BROWN!!!
