It's labeled oil pressure switch, thin yellow and black wire if I can remember.
my surf v8
the oil pressure switch already had the wiring for it in the main loom (single yellow wire with the right plug), I have used this wire and connected it to the alternator wiring and then seen the black/yellow oil pressure switch wire inside the cabin bit of the loom
is one of these not for the oil pressure warning light on the dash?
Just connect the wire thats labelled 'Oil pressure switch' to the alternator 'charge' wire, otherwise the fuel pump won't work.Originally posted by Reece2.4 View Postthe oil pressure switch already had the wiring for it in the main loom (single yellow wire with the right plug), I have used this wire and connected it to the alternator wiring and then seen the black/yellow oil pressure switch wire inside the cabin bit of the loom
You'll probably need to extend the wire to reach the alternator though.
Originally posted by Reece2.4 View PostTurned the ignition on and the earth wire starting melting through, any ideas?
Yeah, you've phucked up somewhere!
I tested everything here with my own ECU and it all worked as it should, even the engine check light.
Let me know where you connected all the wires that I marked up.
