I'm sure its been said before in this thread, but a non-opening valve won't cause no compression.
If you had no valve clearance without a shim in place, it would appear the valve head may have come off the stem, so that the valve operation appears to be ok but the head has gone into/through the piston crown.
If, however, the shim has "just popped out" you need to find out why. It is quite possible that on its way out it caused the valve to stay open and strike the piston....and bent the valve, so no compression...possible hole in piston too.
I feel you're just putting off the inevitable by swapping parts...any engine that won't fire after a FULL TIN of easy start is, generally, foo-baad
147 posts and now some fecer is away with a piston.
