Egr removal
  • Egr removal
    CAR TURNS OVER but wont start all i done was replace turbo and remove EGR valve down where erg was theres orange wire with green stripes going across it? looks like earth wire cause theres no hot wires going to egr ? been off the road for 15 days now trying suse it out can anybody help me
    May be the feed to the glow plugs ?
      a/tps lights warning panel
      hi var i think the problem lies tps having removed EGR ecu went into shut down cut tps car turns over but wont start getting msg ecu car switch off i need disable choke butterfly completly? to open throttle position censor then it should start .how do i do that maybe by removing double butterfly ? or cap it off.i other thing after having removed egr i discovered orange double wire with green stripe across it about every inch on the spad eyelet 12m diamater hole must came off egr? it only thing i took off that side think earth wire not registereing any volts.cant suss were it goes .do you have any idear?
          EGR removal
          hi vagarent checked it all juiced up power going to glow plugs egr has body earth. what colour are the wire? is it orange with green stripe across it every 1" or so .i notice 2 loose wire on one eyelet spade 12m hole after i removed egr but i dont know where they came off a ? egr has body earth . when i was trying to start it i herd low bank cranking it over wondered if i blow something check under the bonnet could smell electrical somewhere near airbox? think something blow?
            Did you blank it or remove it?
            My Surf eats knuckles for breakfast!
              Me too.
              Nev
                EGR removal
                yes i did remove egr. blankd off with plates . now car turns over but wont to start seems like it needs more air input since EGR not there? checked glow plugs ok all fuses ok . did diagnostic check on pins E1 TE1 every 5 sec. red engine lights flashs? on 2L TE code listeded as correction resistance pump? i think either vrt or vrp? where are they located and how do i check them? one other thing got me confused after i removed EGR i noticed brown wire green stripe across it ring type 12m hole turns out live feed 6.8 volts at rear of engine dont know were it bolts on to? discovered it later on. after removed EGR VALVE do you know where goes nev? apparently am not the only in this situation reading an older thread same thing happend another member . but dident say what where that live wire goes thought perhaps you know ?
                  Errrrrrrmmmmmm ......... I'm a bit confused, maybe try using Microsoft word to check grammar then copy and Paste to hear, as I and others by the look of it can't understand what your trying to say
                  www.apmautos.com
                    Non consternationes.
                      haha stupid Iphone is crap
                      www.apmautos.com
                        Errrrrrrmmmmmm ......... I'm a bit confused, maybe try using Microsoft word to check grammar then copy and Paste to hear, as I and others, by the look of it, can't understand what your trying to say.
                        Think that more or less covers the punctuation and grammer...
                        www.johnthebuilder.info
                              ípǝsnɟuoɔ ɯ,ı
