from a previos thread i assumed i could buy up to 2500 ltrs pa of new oil and use it......... not produce up to 2500 ltrs.......... can i just buy and use it?
Either. Production and use of biodiesel or use of VO.
As I read it, you have to keep a record of your usage, not receipts.
Receipts will only prove you DID buy the oil, not that you DIDN'T, which is more the case at issue here.
I keep a record of all the fuel I put in my truck, and note when it is veg and when Derv.
Plus, the mileage is recorded on the MOT, so that should be a valid usage chart. If you do less than X amount of miles per year, you obviously can only use so much.
fellah is just trying to sort out a suitable fuel does he have to skim of the crud on top dont think he had tap on container
Usually crud collects top and bottom, again depends on where oil came from, but get rid of as much as you can, even then 2 days later it will be seperated again
