Waitrose 98p/lt but not many on shelves. even fewer (like none) after my visit
Thinking of using Veg-oil ?
This is a sticky topic.
Originally posted by amethyst View PostI cant believe the price of it atm... 2 years ago kwik save did a sale of half price so it was 20p a liter... now look lol....
glad i get used oil now... bio all the way!
Oh Nana, what's my name?
Now using used oil from a local takeaway, although there seems to be a certain amount of competition for the oil!
I have come up with an easy method of filtering:
Bring home in whatever container I get the oil in.
Decant into black plastic 20 drums (I have an effectively endless supply of these)
Leave for a week in the sun to be heated and cooled repeatedly.
Decant into another container - through a cloth strainer to avoid the floating bits...
Mix in 1/2 - 1 litre of ULP in 20 litres of oil.
Pour into tank.
Drive.
Works for mePeter
I am not a number. I am a FREE MAN!
Sounds good. I suppose anything that gets through the cloth is going to be stopped by the fuel filter - and they're cheap when the fuel is free
Dropped a 25 litre drum off at the local Indian last night. It was necessary to stay and eat, out of respect, obviously.Cutting steps in the roof of the world
After the first filtering to remove the main crud you should then let settle to remove the water in suspension, then be checking the water content of the oil prior to any more filtering. HEAT A FRYING PAN UNTIL ITS SMOKING HOT ADD A SAMPLE OF YOUR WVO if it spits or bubbles leave it to settle longer.
The water content is what will destroy your motor. The food particles get stuck in the filter, so by filtering to 5 micron or less your fuel filter will last longer too as the car filters are rated at about 10 micron.
Originally posted by GIRDLES View PostAfter the first filtering to remove the main crud you should then let settle to remove the water in suspension, then be checking the water content of the oil prior to any more filtering. HEAT A FRYING PAN UNTIL ITS SMOKING HOT ADD A SAMPLE OF YOUR WVO if it spits or bubbles leave it to settle longer.
Originally posted by tintin View PostGraham....... what do you reckon to this (my WVO )?
Alan
p.s., veg oil is coming down in price but equal to diesel, so still no point buying freshOh Nana, what's my name?
