Say hello to my little friend!
Perfect excuse to make some smoke :-)
Think I sussed the fuse problem.
The pump swinging a little in the tank caused the live to rub against the hole I drilled for it. Moved the wires a little and it's been fine now.
I seem to have a lot of pressure build up in the tank, is this normal?
It's quite a lot as it has now pushed the silicone I used to seal the wire entry into the tank near enough out.
ThanksALL THE GEAR!............no idea!
Another quick query about my brakes
I seem to have a lot of travel on the pedal, to the point I'm about an inch off the carpet where the wheels lock up.
I have wound the tie rod attached to the pedal all the way out but it doesn't seem enough.
Would this be due to an old master cylinder possibley?
Many thanksALL THE GEAR!............no idea!
It doesn't leak as the fluid seeps past the piston seals in the M/C as you press the brake pedal instead of being forced down to the calipers.
Does the brake fluid have a black tint to it? If it does then it's a sign of worn piston seals.Last edited by BUSHWHACKER; 31 August 2014, 19:20.
Hi all
Hope everyone's enjoying the sunshine :-)
I managed to unwind the bar a little more in the end and now the brakes are satisfactory thanks for the tips.
I now have another issue though.
I have just come back from a fishing trip to France for a week, set out on the return coach at 0830 sat morn and due to traffic got back to luton at 0230 sun morn. the surf was parked up in a car park for the week. On starting the surf it fired up as usual but straight away cut out after maybe half a second, I tried to start it again and it wouldn't fire. I seem to have lost the spark. I overided the fuel pump so it was on constantly and still no luck. Checked all the fuses and they are all fine. Gave the igniters a tap still no luck, disconnected battery's for a 5 mins still no luck. Ended up having my buddy tow me back to heathrow down the m1 and m25 with a cargo strap, scary stuff.
Any ideas
Thanks very muchALL THE GEAR!............no idea!
Definitely lost spark?
Could be the injectors are not firing. Try swapping the start and master relays relays around see if that makes any difference. Also, give the fuses a wiggle.
Didn't you have fuel delivery problems before and you wiggled something to get going again?
I don't suppose you checked for any ECU fault codes before you disconnected the battery?
