Originally posted by amethyst
Thinking of using Veg-oil ?
This is a sticky topic.
Morning Everyone... i have been offered a supply of oil from a couple of local pubs... they only fry chips in one and fish in the other... my question is...
Do i have to wash it?
if so how do i do it? i have tried to search on here to no avail to find the info.... so any help would be appreciated....
BTW been running on Veg oil 50 - 50 for a couple o weeks now and.....
FANTASTIC!!!! i have never been so pleased to smell like a chippy!
My truck is green in more ways than the colour now .,... lol
Stuhttp://www.manicgamer.net
Stu,Originally posted by amethystMorning Everyone... i have been offered a supply of oil from a couple of local pubs... they only fry chips in one and fish in the other... my question is...
Stu
You don't need to wash it. That's only when producing Bio-Diesel.
I get Waste Veg from my staff canteen and put it through 2 water filters with 25 & 5 micron filters. This gets all the bits out and any sludge leaving just golden coloured oil.
One of the guys on here, TonyN I think, uses an old pillow case to filter his WVO and says it worls fine.
If you want details of my filter set up, send me a PM and I'll give you the details.
DaveJust Vegging Out
Hi Dave,
I got my filters from the following ebay seller
Meare Solutions
He also supplies the polypropelene filters of 25 & 5 microns.
I used copper pipe to connect the filters and have the below transfer pump from
Machine Mart
I have the drum of WVO being drawn into the first 20 micron inline filter via the transfer pump, then straight in to the 5 micron filter and then into a collection drum.
It takes about 15 minutes to filter about 30 litres of oil.
I could probably get it working faster if I used larger copper pipe (using 15mm at the moment).
When I first get the oil, I let it sit for about 2 weeks until it settles. You get a thick gloop at the bottom (depending on how well used the oil is) and golden coloured oil at the top with bits floating in it.
I only filter the golden stuff. The gloop is kept aside and can settle out again. Warmer weather will thin the gloop out a bit too, so you can use a bit of it in the summer, but mostly the gloop goes on the compost or to oil collection bins at the local tip.
Then I put the WVO through a sieve to get any big bits out, and then bung it all though the filter system.
I've used about 80 litres of WVO in a 50/50 ratio. I've just changed my fuel filter after about 500miles of using WVO & SVO.
The truck runs fine. I actually put in straight diesel the other day and found it felt rough, so I topped up with Oil and it felt fine again.
Hope this info helps. Any other queries, give me a shout.
Cheers Dave!!!Originally posted by The HoffmeisterHi Dave,
Meare Solutions
Machine Mart
Davehttp://www.manicgamer.net
TonyN is this true??Originally posted by The Hoffmeister
Cos if it is and it works with no probs at all i can get my hands on loads of waste veg from two chippies just down the road from me.
I was on the understanding it has to be filtered properly??
kev.Regards
Kev.
2.4 black beast
Selective attention is a wondrous thing.Originally posted by falconerOnce filtered with a piece of cloth surly the fuel filter will do the rest??
kev.
Yes, the fuel filter will catch a lot of excess.
Yes, you will be replacing your fuel filter more frequently.
Yes, you do run a heightened risk of knacking something
else.
Yes, it is a quick and pokey method.
Meare Solutions
Machine Mart
Dave
Hi m8... just out of interest qwhat containers do you use? are they transparent plaggy ones? just wondering as how do you know the level of "gloop"
