Originally posted by stormforce
Customs & Excise.
Originally posted by captain_chaosI'd be up for joining in on a bulk discount. How would delivery work? Would it be possbile to collect from your's? Currently getting my veg oil from Tesco in the 15 litre drums, get some funny looks when pushing a fully loaded trolly. Although many club card points! Getting annoying with the filling through a funnel bit though. May have a look at local s$$$$py for a fuel pump, then wire it, hose into the drum, outlet into the fuel nozzel and then pump the oil in Next plan is to find a tax free alternative to unleaded petrol for squeaky.
There's always a Payback .... Ya just don't see it Comin !!!!Buncefield Burner
Originally posted by SurferjessJason try using a 5 litre watering can wfor ya Veg oil
I buy 15l drums of veg, open them and poke a knife through the top opposite the opening, pour from the tin into a 20l jerry can, then i have a jerry can spout which i have pulled the plastic flexi bit off of, removed the gauze, and stuck the flexi back on. Use this to pour from the jerry can into the truck. Takes about 30 seconds to empty the tin of oil into the jerry can, then about a minute or so to pour from the can into the truck.
Quicker and much simpler than farting about with pumps or funnels.
The only reason the 20l steel jerry cans pour slowly normally is because of the gauze in the spout. Take it out and it's nice a quick and clean.=========
=SOLD UP!=
My method is, I put a 15mm tank connector in a spare lid, bit of push fit plumbing, valve, bit more pipe, put container on roof cubes are great, drums need a couple of wedges, pierce the top away you go. If I want to re-use the container I put a self tapper in the hole!Did I mention I have a BLUE one
Tony
Originally posted by fatfiresMy method is, I put a 15mm tank connector in a spare lid, bit of push fit plumbing, valve, bit more pipe, put container on roof cubes are great, drums need a couple of wedges, pierce the top away you go. If I want to re-use the container I put a self tapper in the hole!Cutting steps in the roof of the world
