Tore the Top End of the 3VZ-E a couple of weeks ago, managed it in a single day which pleasing - this was my first time, so I really had no idea how it was going to go..
Had no Bad Luck on the way down, with all the Head Bolts coming out without issue / breakage / snappage etc.
Head Gaskets still in place in the Photo above, so we could inspect the condition and failure point..
The Usual Suspect was the blame, with the Gasket failing around Cylinder Six.. Visible Signs of the failure with a nicely washed Cylinder thanks to the Coolant.. Anyways, moving on..
Heads went off to a local Machinist..
