Ok folks, so I've had a look around at old threads, but am no closer to a solution. Please help
The problem is, that when I slide the heater slider, it doesn't have the right movement because it has a piece missing, which it 'hinges' on, almost could be described as a 'bolt' shaped object. If you see what I mean. And so, with it missing, the slider, now 'flaps'. (for lack of a better word.) And is very difficult to adjust.
Nothing I have tried to repair it with works, which leads me to believe, that I already know the answer. I really hope I'm wrong
Could anybody tell me, if it's possible just replace the piece thats missing, or do I need a whole new heater control unit?
Thanks in advance.
Thanks in advance.
