I had recently been on holiday for two weeks. Surf worked fine when I left.
Got back and batteries were flat. Didn't think much of it at first until I went round the front of it and saw a faint orange glow in the headlights...
Checked inside and, no, the headlights weren't switched on.
I hooked it up to my other car to jump start it. The headlights came straight on. After starting all was normal - lights and spotlights worked as they should. As soon as I switched the engine off the main lights came ON - dipped beam!
I eventually pulled out the headlight relay - which seems to be working fine. It gets a signal to switch on from somewhere else.
Does anyone know what is happening???
(is it because the batteries are very low on power and are causing funny things to happen? Did water get where it shouldn't be?)
