Say hello to my little friend!
  • Originally posted by zem_41 View Post
    It seems that is already the case as when I was messing around with the other day and tried starting it, the truck started rolling forward.
    I have an au to electritian here now trying to work it out. It seems the on wiggling the wires at the relays the starter keeps staying on but wiggle it the other way and it stops, which then allows you to try and start. But again it only fires while the key is in start position.
    You still need to do what I said in the previous post though.
    • Would you happen to have any wiring diagrams you could email over to me please mate?
      ALL THE GEAR!............no idea!
      • Ok buddy will do that, is it this one?
        Seems to be the only blue with yellow stripes with a solid black next to it.
          Thats the one.
          • Yeah have tried that and no difference mate :-(
            • Would you happen to have any diagrams of what you have done at all?
              • Ok the auto spark has given up, he can't work out why the starter keeps staying on, 6 hrs on it and he can't figure it out.
                Would it be possible Vince to bring it to you?
                  Of course mate no problem.
                  Are you going to drive it home after?
                  P.S. Are you getting any codes from the check light?
                  • Well it is pretty much ready to test drive, bar topping up the fluids, but driving it back 2.5hrs is probably pushing my luck.
                    So what I was thinking if this is ok with you of course, one day next week bring it to you on a trailer and leave mine around 9am to miss traffic which would see me arrive to you about midday, you spend 30 seconds fixing the problem then I drive it back on the trailer ha!
                    Obviously on a day that suits you as I'm sure your very busy with other things, and I really appreciate this.
                    This seems to be my only real option as auto sparks assume it's something wrong with the loom and want to open it up to test whereas you would be able to pinpoint the problem instantly.
                    I have only been able to get a glimpse of the led a few times as whenever I try to switch the ignition on it tries to start but when I do the led flashes continuously to indicate no faults.
                    Plus I have not had it running yet so there could be more to come.
                    Thanks again Vince
                    • Any day would be OK, but try and pick a dry one for south Wales.
                      • Good luck with that
                        • Ha ok thanks dude, I'll try my best.
                          Looking at probably tues or wed.
                          I'll let u know as soon as I find a trailer and checked weather.
                          • Gonna go for thurs if that's ok Vince?
                            Hopefully weather will b good.
                            Thanks again for this mate
                              Okey dokey.
                              • All strapped up ready to go
                                Hope the weather is better by you Vince as it's pi&&£ng down here!
                                I'll bring a brolly just in case ha!
