Originally posted by zem_41
View Post
The fuel pump primes the fuel rails when cranking, but won't click over to constant running until the engine fires up and the oil is circulating to trigger the pressure switch.
The fuel pump will stop pumping fuel if the engine stalls when you hit a tree for example.
It also means you can leave the ignition on when checking for any ECU codes.
