It does sound the dogs b&@£cks when it fires though!
Say hello to my little friend!
I was wondering if maybe the posts on the oil pressure sender had been labelled up wrong so I swapped them over, now the dial reads zero and goes up to about 6 on turning over, when I disconnect your oil pressure wire from the sender and switch the ignition on a can hear the pump going but when I re connect it stops?ALL THE GEAR!............no idea!
Thats correct.Originally posted by zem_41 View PostI was wondering if maybe the posts on the oil pressure sender had been labelled up wrong so I swapped them over, now the dial reads zero and goes up to about 6 on turning over, when I disconnect your oil pressure wire from the sender and switch the ignition on a can hear the pump going but when I re connect it stops?
The pump runs when cranking (Key held in start position) and will only run continuously when the oil pressure builds up enough to earth out the oil pressure wire.
If it's a problem with the sender, you can connect the oil pressure wire to the 'L' wire (sense wire) at the alternator instead.
Re: the starting issue, maybe the S relay is faulty?
Did you connect the three wires at the ignition multi-plug to the wires I showed you in the photo?
I did yesOriginally posted by BUSHWHACKER View PostThats correct.
is that the one that's bolted to the post?
yeah I thought the same so swapped it out with a new one but still same, it's intermittent though as I had about 8 cranks and it was fine but then it came back again
Did you connect the three wires at the ignition multi-plug to the wires I showed you in the photo?ALL THE GEAR!............no idea!
I tried connecting pump to the ignition switch.
it still tries to start on its own even if the key is only turned to the ignition on position not the start position.
But when it doesn't do this and I try to start, it fires and sort of runs but only when the key is in start position, as soon as I turn the key back it stops dead, if I throttle while starting it revs up a little but again only while key is in start position.
Confused.com
Could the two wires going to the ignition switch be the wrong way round to cause this?ALL THE GEAR!............no idea!
Originally posted by zem_41 View PostIt seems that the starter only gets stuck on when the truck is in neutral
Any ideas?Originally posted by zem_41 View PostCould the key sensor that was around the barrel be the problem with the not running?
Thanks
Hmm, sounds like the neutral start switch is back feeding 12v to the starter relay.
OK what you need to do, is unplug the largest plug from the ECU, (34 pin plug on the far left) find the thin blue wire with a yellow stripe (Pin 13 which is between a black wire and black/white wire) and snip it approx 6" from the plug and tape over the end and wrap it into the loom.
Then with the 6" length left at the plug, solder a length of wire to it thats long enough for you to connect ignition 12v to it.
Just be aware though, that the engine will be able to be started in any gear.
It seems that is already the case as when I was messing around with the other day and tried starting it, the truck started rolling forward.
I have an au to electritian here now trying to work it out. It seems the on wiggling the wires at the relays the starter keeps staying on but wiggle it the other way and it stops, which then allows you to try and start. But again it only fires while the key is in start position.ALL THE GEAR!............no idea!
