Hey guy's, surf has been coughing out white smoke, difficult to start, at one point was hydro locked, but turned over eventually, I cant afford to pay a garage to do a head job,so I have started striping down bits and pieces myself,
I am using the 1Kz-te PDF manual for guidence but I am still finding things tricky(not an experianced mechanic)
I am at the stage of removing the turbo, but I am wondering how to remove the Turbine outlet elbow, the pic in the manual is a bit confusing, is anyone got other guides or info on how to access the 4 nuts that the manual refers to?
also, will I need a breaker bar, or just a torque wrench? also will I need this
09268-64020-01 DIESEL INJECTOR SOCKET WRENCH?
and is it worth doing the water pump, thermostat and glow plugs at the same time, I will be calling stevo for a head this week.
I hope I dont feck this up,
thanks v. much.
Paul.
thanks v. much.
Paul.
took 3 hrs to get head off.Take off all the bits over the head,leads,vac pipes(i took pic's of where it all went)then took sheild off the turbo and unbolted it from the manifold on the inlet side took pipes off back of pump.Made sure cam was lined up took belt off then Undid head bolts and lifted off all in one took manifold's off on the bench.In all cost £1100 head from rough trax,rad etc etc but worth it and felt good knowing i had done it
