The VSV plugs have two wires. One is positive the other negative. Black/White Stripe is negative on all I think. When testing connect multimeter to both terminals. Easier if you have a helper to pess button etc as suggested. Have the engine running as well so you can pull hoses and check for vacuum from each VSV if plugs test ok and after reconnecting to the VSV.
