Originally posted by TonyN
Suddenly, Im a boy racer........
My karma ran over my dogma ..
Paul
Simple answer. Any engine, other than one which has been tuned, can be tweaked. However, you shouldn't starting making random changes unless you are monitoring things. Absolute minimum you should have to monitor it for these types of mods are an accurate coolant temp gauge and a pyro/EGT gauge. Those two between them will let you know how well the engine itself is coping.
Originally posted by MattFSimple answer. Any engine, other than one which has been tuned, can be tweaked. However, you shouldn't starting making random changes unless you are monitoring things. Absolute minimum you should have to monitor it for these types of mods are an accurate coolant temp gauge and a pyro/EGT gauge. Those two between them will let you know how well the engine itself is coping.My karma ran over my dogma ..
Paul
Like Matt said, anything can be altered a little, its knowing when to stop, most manufactures err on the side of reliability, so you have scope to alter it a little, without it blowing up in your face, but there is a limit, to rich, to lean, to much boost, etc.... will always end in tears, or my wages..
I don't know how far you can go, learn from others mistakes.4x4toys.co.uk - Keeping you on and off the road...
so just to ask the same question again Tony, isnt there a recommended starting point for this adjusment screw, so many turns out from fully home, so i can figure out where it should have been in the first place? If the pump were stripped for a rebuild there must be an approximate starting point to set it to ?My karma ran over my dogma ..
Paul
Originally posted by Billy-No-Moneyso just to ask the same question again Tony, isnt there a recommended starting point for this adjusment screw, so many turns out from fully home, so i can figure out where it should have been in the first place? If the pump were stripped for a rebuild there must be an approximate starting point to set it to ?
Deisel pumps are far intricate than carbs, and you need lots of specialist tools to set them up.
If you get a couple of people to see how many turns, from bottom to how it is now it would give you rough idea, but I try not to mess with the pumps to much as they are expensive to sort out. and it can go pear shaped quickly.
cheers chaps. Ill work on the premise that there is a little leaway with the adjusment and take it back to a quarter turn anti clockwise from where I started. By the way,Indicative Indication is a redundant syntax. I may not know much about engines but me grammer int arf good.My karma ran over my dogma ..
Paul
Originally posted by TonyNooh, get him....
Originally posted by Billy-No-MoneyBy the way,Indicative Indication is a redundant syntax.An indication is merely a notification of something. An indicative indication is an enhanced and more precise notification/quantification of a base [something]. (When will you lot ever learn)?
Originally posted by MattFYou wish.
Actually, it's not.An indication is merely a notification of something. An indicative indication is an enhanced and more precise notification/quantification of a base (something). (When will you lot ever learn)?
