going to remove air con
  • #31
    well i have been thinking
    and the conclusion i have come too
    is
    I'm not going to bother
    • #32
      • #33
        is
        Haven't you been told about thinking?
        You could always try my technique,
        it's not highly recommended,
        but it works.
        Damage it
        Gone from 4x4 to 1x2
        • #34
          is
          Wimp
          What have I told you about thinking Erroll
          • #35
            Originally posted by shokenore View Post
            APART from the legal aspect NO it is NOT safe to let the gas out.
            It is under pressure.
            It is a liquid with a boiling point of about -34 Deg C.
            Cold burns are not nice .
            Like I tried telling you last night by using the example of other dangerous things you shouldn't do but as you missed the point then and still do not seem to understand.
            Let me repeat myself.
            The gas/liquid mix that WILL come out will either fall in droplets or condense onto your hands arms or whatever other body parts you have exposed as the mixture will have a lower boiling point than you it will suck the heat from you this will leave you with cold burns add to this the possibility that the lubricating oil in the system will have an acidic level aswell oh yeah and the gas is toxic so please do not breathe it in.
            Take it down to ur local wefit or whatever and pay the guys to reclaim the gas.If you lived nearer I would do it for free being a so called "specialist".
            There you have the options the diy route unlawful and possibly harmfull,or the safe legal route.
            I foolishly ventured a similar opinion regarding the release of these gases a while back & got slagged off for it. Sorry to say this but, you're just peeing in the wind with this one.
            I guess one or two are wondering when I'd stick my tuppence worth in!
            • #36
              Legionaires disease is not caused by A/C. It's found in 'cooling towers' & not all are A/C cooling towers either. These cooling towers are gradually been phased out thankfully.
              • #37
                Again not totally true ......It can be found in puddles on the street ..... and in your house
                It is only a issue when inhaled as droplets in the air
                http://www.hse.gov.uk/legionnaires/whatis.htm
                http://www.hse.gov.uk/pubns/spalegion.pdf
                Cooling towers are just a small part of it and it's thinking like that that put's people at risk .......
                • #38
                  you can all stop now
                  honest
                  • #39
                    Coward.
                    • #40
                      I'm going to tip some White spirit in the fishbowl...but only till I can find some aerosols with a high cfc content, I can go puncture.
                      Non intercooled nothing.
                      • #41
                        your all just silly sods
                        • #42
                          good morning andy n graham n ian
                          • #43
                            Hello...must be off...need to chuck some disposable nappies in a landfill.
                            • #44
                              http://www.amm.co.uk/files/factsabout/fa_leg.htm
                              legionnaires disease is in air con and its more common that you seem to think
                              hence why i no use air con
                              • #45
                                *ahem*
                                "Air conditioning systems may constitute the greatest hazard. The organisms multiply in the water of cooling towers in which a cascade of water is used to cool air in pipes or vanes."
                                *ahem*
