Broken Halfshaft!
    I wish I'd been there to see how the Spanish chaps got mine off! Having seen the old bearing, they'd been at it with an angle grinder - I do hope thats all they used!
      Cutting it without heat would be the way to do it.
      I think you'll be fine Andy if they used a grinder.
      Alan
        usually a bearing puller is the way to do it!
          yeah, cutting is still a chore without nicking the 1/2 shaft.
          I made a copy of the special tool out of 1/2 an old axle casing, bolt it to the bearing carrier, pop it in the press and hey presto, one unstressed or damaged axle shaft.
            agreed, but if caught out with limited tools then grinder would be preferable to heat.
            Alan
              lol, i was going to say have you changed the bearing in the past with a torch?
              change the bearing properly, or don't do it!
              never use heat near a axle shaft. Exciting times.
              So glad you know wot ur doing Tony...I would just hit it wiv a hammer...!
              Think I will let you practice on mine ;-p
              Nissan Patrol for on-road, and a Land-Rover 110 shed for off-road :-)
