I note you want something close to stock. I also note that LC springs are still being offered as a choice.
For stock, do not use LC springs. They are much taller and much stiffer than stock and will mean whether you like it or not you'll need to wind the torsion bars up a long way to level the truck, which will then give you a harsh ride from the front to match the new harsh ride from the rear!
If you're not sure whats under there at the moment, or what you need to do to sort it, then get someone local who knows to take a look.
Tony N is the man, but for one reason or another may be busy.
