Coil Spacers
  • #61
    I note you want something close to stock. I also note that LC springs are still being offered as a choice.
    For stock, do not use LC springs. They are much taller and much stiffer than stock and will mean whether you like it or not you'll need to wind the torsion bars up a long way to level the truck, which will then give you a harsh ride from the front to match the new harsh ride from the rear!
    If you're not sure whats under there at the moment, or what you need to do to sort it, then get someone local who knows to take a look.
    Tony N is the man, but for one reason or another may be busy.
    • #62
      Apache is correct, the LC ones will be higher and harder ( I still think they drive fine but thats just my opinion) fitting uprated standard height springs and standard length shocks may be better for your needs.
      Standard wheels will still be fine with this setup.
      The LC springs are excellent for heavier payloads but perhaps to stiff for your intended use.
      My truck will be getting LC's ES9000's and balljoint spacers with manual hubs but I intend to keep offroading as much as I can.
      yoshies truck (blue truck) is setup like this but with the addition of 33" tyres and a 2" body lift
      the grey truck is mine at present, fitted with uprated standard height springs and factory toyota shocks.
      Alan
      • #63
        this pic is a standard spring compared to an LC spring.
        Alan
        • #64
          fitting springs and shocks to the rear is pretty straightforward.
          Alan
          • #65
            I'm on LC springs too, and, like you, I'm OK with the hard ride. It would be nice if there was a spring with an at rest length which gave a 3" lift, but at the same spring rate as an original Surf spring. You'd get a better road ride (if a bit wobbly) and easier flex offroad.
            I know you can get em custom wound. Wonder what the cost of having some made would be? I'm sure there's a market here...
            • #66
              I think the LC's are rated a bit too high for Surfs but they work great at lifting them so 33's can be fitted. Great for heavy payloads too.
              Adjustable springs (like some motorbikes) would be the way forward.
              like this perhaps http://www.rallydesign.co.uk/product...oducts_id=3450
              Alan
              • #67
                Torsion bar writeup.
                http://www.sdori.com/theory_of_operation.html
                Alan
                • #68
                  balljoint writeup http://www.sdori.com/SDORI_4WD_Spacer_Install.html
                  Alan
                  • #69
                    Hi All Thanks For All The Info
                    Just Clarify To Get My Truck Sitting Like Alans I Need
                    Standard Length Springs Where From How Much
                    Standard Shocks All Round Oil Or Gas Again Where From And How Much Part Numbers Would Be Great If Poss
                    Alan Can You Give Me The Full Sizes Of Them Tyres Thats Exactly What Im Tring To Achieve With Out My Kit Obviously
                    Thanks Again
                    • #70
                      My tyres are General Grabber AT's 265/70 R16 ( can also be bought as a 15)
                      Alan
                      • #71
                        standard coil springs and shocks for your truck on this page
                        http://www.milneroffroad.com/categor...?cID=11966&p=2
                        Alan
                        • #72
                          Cheers Alan I Shall Get Them Ordered
                          Is It Worth Ordering Suspension Shock Absorber Bushes And Bump Stops To GET IT All At Once Then I Know Thats One Job Out Of The Way For A While I Assume I Dont Need The Balljoint Spacer With This Setup
                          Thanks Again Mate
                          • #73
                            standard height procomp ES9000's here, just need to select your vehicle, 4-Runner
                            http://www.supertrux.com/acatalog/ES...Absorbers.html
                            Alan
                            • #74
                              your new shocks come with new bushes.
                              If your bumpstops look damaged then yes I would order them up.
                              Alan
                              • #75
                                no need for balljoint spacers with this setup.
                                Alan
