Originally posted by Fish
South Lakes Expidition (45 miles, Green Laneing)
Originally posted by FishNow we have -
Fish
Gizmo
Ohsupremebeing
Grimreaper
Kazam401
Fatcat8
Fish
Walkie talkies would be very handy on this venture, I have 3 to bring along, anyone else bringing some would be most welcome.
Wot about two tin cans and along piece of string...will that do?Gaz
Originally posted by GizmoWot about two tin cans and along piece of string...will that do?xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Originally posted by fatcat8What frequency are they on?
I've got 7 handheld radios I can re-program to match.
Channel Frequency Chart
CH. No CH. Freq.
18 462.6250
19 462.6500
20 462.6750
21 462.7000
22 462.7250
Does this help youBEWARE OF THE REAPER
Originally posted by fatcat8Ok, no problem, I can sort those frequencies.
Do you use any CTCSS or DCS codes?
If you're not sure, let me know the make and model of your radios.
They are Midland G223 2watt upto 7mile (in perfect conditions)BEWARE OF THE REAPER
Some radios transmit a sub-audible tone or digital code everytime they transmit. The receiving radios have to be set to the same code before they will open up the receive side or squelch so that the received audio can be heard. This is basically to help with radio congestion.
I'll do a check now on your model of radio.
If it looks like it may be an issue, I can probably meet up with you before the 25th and actually scan the code out of your radios and program the same code into mine.
Originally posted by fatcat8Some radios transmit a sub-audible tone or digital code everytime they transmit. The receiving radios have to be set to the same code before they will open up the receive side or squelch so that the received audio can be heard. This is basically to help with radio congestion.
If it looks like it may be an issue, I can probably meet up with you before the 25th and actually scan the code out of your radios and program the same code into mine.BEWARE OF THE REAPER
