The front doors are longer on the two door, they're the same as the Hilux pickup.
New Build
I didn't know that. I might look for a new hi lux carpet hopefully easier to get than a surf one.Originally posted by BUSHWHACKER View PostThe front doors are longer on the two door, they're the same as the Hilux pickup.
I would like to tart the interior up given the work going into the rest of the truck.
I have another 4 door 2nd gen here I will get a tape on the over all body sizes for comparisonLast edited by yoshie; 7 April 2013, 21:21.Brian
Originally posted by yoshie View PostI didn't know that. I might look for a new hi lux carpet hopefully easier to get than a surf one.
I have a four door Surf carpet here for sale, I was going to scrub it up and dye it black before sticking it on my parts for sale thread.
£25 cleaned or £40 cleaned and dyed black.
just wie you sealing and bonding wood in bud, nowt worse than black build up under the boards seen a few vw wie it, trapped gunk an water an its easy to wash oot lolOriginally posted by KERRSURF View PostHow many pickups you see with holes in the bed?
still looks gid thoughdont follow the rut`s......make yer own
He's writing in an accent I think, or he's just uniquely peculiar in his spelling!Originally posted by BUSHWHACKER View PostPardon?
It sounds scottiish when I read it...and i can't understand a word they say... so it's perfect!
Brian,
My liner doesn't have any holes... before i sealed the back properly, if you parked nose down, there would be a swimming pool in the back.
I suppose as you suggest, stripping the tailgate of rubbers will allow any water to drain quite easily.
Maybe putting a drain hole into the original truck bed might be not a bad idea just in case you get any trapped water, ut I wouldn't go drilling your wood bud."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
Nae need for drains, there is a nice wee gap at the rear tailgate that and water will run out of when the truck is on an up slope.
The bed will be fully sealed and the speedliner is used on wave pools because it's 100% effective and very hard wearing.
http://www.surfparkcentral.com/ameri...ve-technology/
Bed edges sealed with aircraft epoxy tonight, will need sanded to shape once hardened.
Alan
Cheers Robin. we have the option of removing a few large grommits from underneath the truck if it lets any water in, but my liberal use of all the bonding and sealing agents should hopefully do the trick.Originally posted by rjd1 View Postjust wie you sealing and bonding wood in bud, nowt worse than black build up under the boards seen a few vw wie it, trapped gunk an water an its easy to wash oot lol
Alan
