Not much 2'' left as I had to do those sliders today. I had a little faff about last thing and started to mocked this up. None of the joints are coped and its just tacked together.
8 bolts in the brackets on that bottom tube so it is solid perfect for a couple of recovery points.
Need to bend round the sides and replace that top one with a longer one I can bend round to the arch.
Do you think the stinger needs to be a few inches higher, it definitely needs to move out another inch.
Carried on with the mock up of the front bumper.
Opinions welcome on whether I should go with the infill sections which I would drill with some sort of hole cut pattern or do I leave them open.
I know its not level it's just a bodge of an idea for now.
You can see the side and top mounting points is these two and a brace I fitted behind the main tubes nice and solid even in tacked un-coped
