Will this mod work on my gay gen?
simple steering mod
I changed the rack bushes the other year, can't say I've noticed any sloppiness in the steering at all.Originally posted by BUSHWHACKER View PostHaven't looked into it, but you have a steering rack and I don't think 3rd gens have a 'rag' joint.
The sloppyness in the steering is cause by worn rack bushes.
Just thought it would be one of those mods even I could undertake.
You could probably find something here if you want a fiddle with your truck.....Originally posted by si tate View PostI changed the rack bushes the other year, can't say I've noticed any sloppiness in the steering at all.
http://www.top4runners.com/topsites/index.php
theres not much point in a plate if the rag joints removed - it bolts straight up. a plate wont make it any stronger or give any benefit.Originally posted by Albannach View PostDoes anyone know the PCD of the bolts? I fancy this mod too, but would rather replace the rag joint with a plate, or add a plate(s) to the joint.
you only need to lengthen the shaft if it has been lifted and i'm sure yoshie will have a wee bit pipe to glue on.
i think vince made a spacer cos he didn't have any pipe to hand.
you will notice the difference in the steering straight away
