Originally posted by Bibs
View Post
What thickness bar for rock sliders ?
Hi Bibs,
I've been searching on sliders for a while and there doesn't seem to be a definitive 'best' option.
Personally I'd prefer bolt on as it's less permanent on the truck, but I may have to go with welded as I don't have a bodylift which makes things tight.
I'm drawn to the 'bolt through chassis' method which involves drilling through the chassis and welding tubes into it.(stops the bolts crushing the chassis) this is do-able without a bodylift and seems fairly easy.
Doubt that helps?
Rob
Not sure which is best tbh - stainless is a btch to drill or weld so I am toldOriginally posted by wishbone View PostHi Bibs,
Doubt that helps?
Rob
thanks though
As far as I know it's really horrible trying to weld stainless to normal steel aswell, which would push you towards the bolt on method.... but I may be wrong.Originally posted by Bibs View PostNot sure which is best tbh - stainless is a btch to drill or weld so I am told
thanks though
Rob.
There is an alternative method of doing that which requires no welding. The holes which sit behind the mounting plate are drilled out wide enough to slot the strengthening sleeves in. The holes on the opposite side of the chassis rail are only drilled wide enough for the bolt itself to go through. You then have a setup where the sleeve can't slide completely through the rail and it butts up against the back of the mounting plate and the far inner face of the chassis rail. As soon as the mount and bolt goes on, you're sorted.Originally posted by wishbone View PostI'm drawn to the 'bolt through chassis' method which involves drilling through the chassis and welding tubes into it.(stops the bolts crushing the chassis) this is do-able without a bodylift and seems fairly easy.
I had to read it twice to get my brain in gear but this makes sense, less welding to do as well.Originally posted by MattF View PostThere is an alternative method of doing that which requires no welding. The holes which sit behind the mounting plate are drilled out wide enough to slot the strengthening sleeves in. The holes on the opposite side of the chassis rail are only drilled wide enough for the bolt itself to go through. You then have a setup where the sleeve can't slide completely through the rail and it butts up against the back of the mounting plate and the far inner face of the chassis rail. As soon as the mount and bolt goes on, you're sorted.Alan
