Hi all, I've recently had a loud ticking start on the engine hilux surf (3.0 TDI). It was fine until I had to tow my caravan up an incline and now its really loud all the time. Theres no real power lost and it still goes, nor is it overheating. sounded like could be a cylinder, injector or maybe jumped a tooth. So i change timing belt and tensioner and pulleys were all set up correct, took rocker cover off checked cams and shims which are all fine and tight, checked injectors by slackening off while it was running, they didn't make a difference, put new filter on and over the last 5 days 2 lots of fuel cleaner in filter, red x diesel in tank, engine flush and new oil change with additives as well but still there, tick tick tick. I noticed if i run it up to about 70mph 3500rpm when i take foot off the gas it goes as revs drop but come back when they hit 1000rmp. Anyone had this problem before? Any advice would be well aprieciated as its doing my head right in now. Have had the balls to go right in for cylinder or injectors as I'm an amateur mechanic :S
HELP
HELP
