Where in Abercarn are you fella? my wife is from Abercarn and I'm from Cwmfelinfach. have you got a garage in Abercarn?
Engine ticking problems
Kinda sorted
Right, engine is all back together and turning over, new piston in but for some reason it turns over on the key but just won't fire up and keep going. Not sure what I've done wrong or if there are some air pipes on wrong but spent most of today on it and still got nowhere. Cracked off injectors and fuel is pumping, plugs got power going to them but all them little pipes at the back of the rocker cover? Lost me. Any chance you could pop to the unit to give your advice Vince fella? Your the man in the know.
Alright Vince, tried ringing you earlier. Thought I'd have one last go at the jeep before calling it quits, and it runs alright up to temp for a bit then after about 20mins of a run around in it, it starts overheating then the temp drops back down then back up n down again. When I got outside the house it was billowing greyish white smoke then I rev'd it full and then smoke went until I took my foot of to let it idle and it started spewing smoke again.
Alright Vince, I've got and engine, gearbox and exhaust system for my own conversion. £250 and getting it on Saturday. Need to speak to you about one or two things when taking out old and putting in new as going to do it Sunday and next wk. also if you could do me a wiring loom. Tried to ring but no answer
£250 including, Transmission, ECU, All of the ECU plugs, Igniters, AFM, Alternator and A/C pump?
Sounds too good to be true.
Info costs time and money fella, this is my job now remember.
Have a read through all of the Lexurf build threads, all the things you need to do regarding the conversion are there in the photos.
p.s. My phone is in the garage, it's a bank holiday today!
Ps I realise it is a bank holiday but I only came upon this idea after talking to you, also I did say I'd be doing it myself and you suggested you could help me with the electrics side of things. but looks like I got the wrong end of the stick. Won't bother you about it again and i can see I have been a pain.
