OK this may be a stupid question but I'm going to ask anyway.
My front diff was leaking oil and until I get round to changing the oil seal which I have sitting in the garage, I need to check the level as it has stopped leaking and I am thinking that it may be because there is nothing left in it to leak.
Am I correct that the filler plug is at the front of the diff just above the ADD actuated warning light sensor, in which case......
How the hell do you get at it without dropping the AC rad. Are my hands just to big and even if I can get the plug out (think it's supposed to be 24mm) how do you top it up.
Or is there another plug that I can't see.
