Thanks Richard, I'll go and try that now. I got in touch with Vince too, he's offered to change the glowplugs bless him
I need some help please guys . . . Runs fine but trouble starting?
Tried that
Hi Richard
Tried that, that's if I've done it right, there's a little screw on top of the fuel filter I undid that and tried to pump as you said, couldn't see anything moving except the spring to be honest?
That said, if it is that there was no 'pressure' apart from in the spring. Also in the fuse box under the bit that's marked fuel warmer, there is just a blank square that looks like something should be plugged in like a fuse? It's about 3/4 inch square'ish?
Batteries are starting to get low nowTo charge the batteries do I need to do it in any particular order? as there are two, if I disconnect and leave on the truck and take the charger out there on extension lead is that ok?
Thanks
AdarshaLove me Love my Surf!
you don't need to undo that little screw on the plunger at all.Just pump it up till it gets stiff..( keep it clean please) if it dont the try some viagra.
just disconnect the one battery and put it on charge while still on the truck as that will be ok
that blank fues fuel warmer only certain truck had the heated fuel primer/heater fitted so you probably haven't got it so no need for the fusehttps://www.facebook.com/groups/henpals/
lol... thanks Richard.. I think I must be either doing something wrong, or stupid, or both! lmfao
But the thing on top of the fuel filter did not appear to have any movement unless I undid the screw. Also, I have now tightened it down, is it possible to tighten it down too far... worried now? eeek!Love me Love my Surf!
I worked it out
Hi Richard,
Got the battery on charge now.
Yes, I think it's the fuel primer. I worked it out. After about 8 or 10 pumps it feels the same still. I'll have the one you have if that's ok. If it's easy enough to put on I'll have a go myself, if someone wouldn't mind explaining how to do it, it doesn't sound like it'll be that difficult, not a huge major part is it?
I'll email you so you can send me details of how to pay you, that'd be awesome. ThanksLove me Love my Surf!
All you need to do is take the fuel filter off and then the 2 x 12mm bolts that hold it to the bracket and thats it.
Paypal is to stormforce1067@sky.comhttps://www.facebook.com/groups/henpals/
oky doky
oky doky
I'll get the paypal payment to you now, don't worry too much if you can't get to the post office??? I don't know what the roads are like with you down there. Main roads ok here, just side roads bad.
Will I have to drain any fuel or do anything like that when I change this? sorry to keep picking your brains... lolLove me Love my Surf!
Originally posted by T1z3R View Postjust a heads up but the primer does have the ability to lock in position if turned (the black part not the screw). i discovered this only recently.
just wondering if it's meant to be locked down or not now? Anyone know?Love me Love my Surf!
Update!
Well, charged both batteries. Primed the fuel filter.. and it started first turn. Thanks again forumites !!! as usual a great source of information and guidance.
And thanks Richard for arranging another primer for me, much appreciated. Let me know when it's on it's way so I can look out for it in the post. We have dubious postpeople here...lolyee ha
oooo I love my Surf!Love me Love my Surf!
