Feck this is sounding more complex than ever..........will let you know how much Toyo quotes tomorrow
Got the old bearing off at work last night, using some made up tooling and plenty of different sized bolts, worked well
job done, re-fitting the bearing, locking rings and ABS sensor gear was a doddle compaired to removal, especially when your tooled up (4 foot mild steel tubing with custom made ends, and 4lbs raw hide mallet)
