It could be something simple as the timing belt has jumped a tooth on the fuel pump sprocket, did the garage check the timing marks are aligned?
got me stumped!
You need to pay the £10 members fee to upload photos I thinkOriginally posted by maxwell-1unable to upload pics but can send it by email!
should be easy to see as it attached to turbo sensor in a clip on side of block.
Cheap twice the price given all the expert help you get on here
Brian
hi theres been some new thing happening now.
it seems to pull and then drop back while driving and throwing out a lot of smoke when reved and changeing gear,and loads when foot down,i thought it was on fire!!!BLACK SMOKE LOADS!!is it turbo..?
its getting very bad..
help
does anyone know if their is any one who could fix a cylinder head on my 2.4 in the surrey or middlsex area,tony in berkshire is fully booked but im getting the head from stockport, i do not trust any garage as ive been ripped off before,
thanks phil.
TIME TO UPDATE
FIRST- The only diesel bob i could find is 200 miles away up the north!!
SECOND-I have called a local diesel chap and he thinks it's air getting into the system,
or the fuel pump.
He said sometimes it's because the pipe in tank is off or split.
He wants me to bypass the tank by fitting a small tank under bonnet to see if the shakeing stops.
i have a tank and have taken the return feed from the prime tank off and plumbed this into one end of tank and now looking for feed to main pump,is it the one with a with a white stripe on it?this is mounted into the top of fuel pump and connets to a metal pipe just in front of prime pump..
