hi the truck seems to running like a cow again,just cost me an arm and leg for diff replacement as seems to have lost its teeth..
now we have ofter issues.
its running ok once started and runs fine until its warmed up then when you stop or slow down where it jumps,shakes and some time stools when you stop or pull up,but most of the time just starts shakeing .
so much shakeing things even fall off the non slip mat on the dashboard.
what could it be???
the truck is a 94/L kzn130
manual
its been doing it now for about 3 weeks.
it was doing it before the new diff was fitted.
i did find a little water in the fuel filter but not changeD this yet as letting tank run down first.
i've changed the oil and checked all the hose's around the turbo and the bulkhead.
PLEASE HELP!!!MY HANDS ARE START TO HURT HOLDING ON TO THE WHEEL WHEN IT SHAKES..
what could it be???
manual
