I had problems with the screen washers repeatedly blocking up. It wasn't the nozzles but the non return valve, which is inside a straight connector,on the offside of the T-piece on the drivers side. The non-return valve had clogged up with soap from cheap screenwash fluid and grit. A blast out with compressed air has sorted it for now but I will fit an inline filter.
Warning: The fibre glass sound proofing under the bonnet makes your hands itch like hell!
