Windscreen Washer Woes - Sorted.
  • Windscreen Washer Woes - Sorted.
    I had problems with the screen washers repeatedly blocking up. It wasn't the nozzles but the non return valve, which is inside a straight connector,on the offside of the T-piece on the drivers side. The non-return valve had clogged up with soap from cheap screenwash fluid and grit. A blast out with compressed air has sorted it for now but I will fit an inline filter.
    Warning: The fibre glass sound proofing under the bonnet makes your hands itch like hell!
    It's only a hobby!
    Warning: The fibre glass sound proofing under the bonnet makes your hands itch like hell![/QUOTE]
    that'll be be the stuff that filled up with mud/water got too heavy and fell off onto the engine, was it important
    Diesel, like petrol only better
      that'll be be the stuff that filled up with mud/water got too heavy and fell off onto the engine, was it important [/QUOTE]
      Not really. Just helps damp the noise.
      It's only a hobby!
        mine got left in bedfordshire after i washed it with a fire hose!
