Recently did my 2nd gen hub upright bushes due to erratic howling noise, not much wear to see when the old ones were out, but what a difference it made! No more noise, I did as others had suggested and removed the drive flanges from the hubs to immobilize the drive shafts to isolate the noise. Took the opportunity to do a couple of other jobs at the same time, track rod end/bottom ball joint/front pads. Greased the hub bushes and driveshaft well before replacement, when I was happy the noise hade gone away I fitted a pair of AVM manual hubs, so thats a job that shouldn't need doing again!
regards
John
regards
John
