Headlight Bulbs
  • #31
    relays were local to their battery, one pair on the left, one on the right.
    As Morr had suggested. one relay per element...
    Jotto, how are your lamps behaving...? still going strong?
    • #32
      They are fine thanks
      I'm a custard donut monster
      • #33
        excellent, as soon as I get my workshop space sorted out, I must get round to making myself a set up... (ooops still not done it...) Mind you there are areas of the garage floor that I can actually see and stand on... so nearly there...
        • #34
          Headlight loom
          So how's it going then are you any closer to having a finished loom available for us wot don't want to do it ourselves?
          How much!
          • #35
            Certainly have... Jotto has been testing the prototype for some time now...
            I will have installed a set shortly too...
            • #36
              Ipf?
              Who and where are IPF, please?
              I am still waiting for my first Surf in September. I am interested to see the information about headlight re-wiring. Is it really needed for 100/80 bulbs? I put these in various Fords over the past 15 years or so, without changing the headlight wiring and without having any problems. (I was told that any higher rating would need modified wiring).
              • #37
                Wire them up with their own supplies and switching circuits. You can
                use the existing wiring as the live feed for the control relays, but I
                wouldn't recommend it for the lights themselves. Keep them seperate.
                • #38
                  I've got them in my truck with standard wiring. Been fitted for two years now with no probs!
                  • #39
                    100/80 bulbs
                    Thanks - it would be much easier if rewiring could be avoided!
                    Has anyone actually suffered damage from fitting 100/80 w headlight bulbs to a Surf, without modifying the wiring?
                    • #40
                      See my previous post!
                      Also, the MOT man passed them and he even adjusted them for me as the beams were pointing at the ground after raising the rear suspension 3 inches!
                      • #41
                        Sorry. Thought you were referring to running seperate lamps,
                        not just changing the headlamp bulbs.
                        • #42
                          Only wanted to change the bulbs
                          I was only wanting to change the headlight bulbs to 100/80s, not to add extra lamps.
                          I looked at the PIAA site for the first time and was amazed by the extortionate prices for their stuff - it looked like a spoof! I'm probably being naive, but I can't believe many people would be willing to pay such prices for headlight bulbs that are just a colder colour (no figures are quoted for light output in lumens, so how do you compare?).
                          Having said that, I wonder how LED replacements for rear fog, brake etc lights measure up?
                          • #43
                            Personally, I still prefer bulbs for lighting purposes over LED's. But, there
                            are drawbacks.
                            Bulbs have a good all round light dispersion, which is also more suitable
                            for usable light. I know that bit sounds daft, but try a LED torch against a
                            standard torch, and you'll see what I mean. Bulbs however, are more
                            prone to shock, have a lower operating lifespan and require more current.
                            LED's have a far poorer light dispersion, useful from directly in front but
                            poor side light. It's pretty much whichever takes your fancy. LED's would
                            be fine for something like brake lights, where the normal viewing angle is
                            from practically straight behind. Personally, I would only use LED's for the
                            type of purpose that they have been used primarily. Instrumentation and
                            backlighting and also diffused illumination.
