Hi in need of help my 3.0 Ken 130 1995 is struggling to start it has new cylinder head and when it starts it runs perfect I have checked glow plugs and work really well but do not seem to get power on start-up I can hear relay come on and off 1 or 2 seconds and after 20 off all together but no power at glow plug can any one help
Glow plug
Glow plug
also check the voltage at the glow plug relay mounted on the inner left fender. My Surf is the same year and model of yours. I am currently diagnosing glow plug issues with mine. If the engine is warm at all the glow plugs only come on for a fraction of second. Cold they are on for 20 or more seconds. Which is completely normal ( i think). The dash glow plug light seems to work independently of the glow plugs actually having voltage, always 2 or 3 seconds on hot or cold so i think i am going to install a light from the wire that goes to the rail. I installed new glow plugs last winter and I think i may have one or to faulty ones now as cold starting is horrible. When its warm it fires right up and purrs like a kitten. I would be glad to compare tests and assist you where I can.
