Glow plug
  • Glow plug
    Hi in need of help my 3.0 Ken 130 1995 is struggling to start it has new cylinder head and when it starts it runs perfect I have checked glow plugs and work really well but do not seem to get power on start-up I can hear relay come on and off 1 or 2 seconds and after 20 off all together but no power at glow plug can any one help
    Is there a fault with the wiring circuit ( broken wire or connection missed when the head went on ), possibly the glow plug fuse has blown, think it's an 80amp one
      As above. Check glow plug fuse. If blown check glow plug rail is properly insulated.
      Nev.
        Thanks will try visual inspection of fuse looks ok but will take it out to have better look
          Glow plug
          also check the voltage at the glow plug relay mounted on the inner left fender. My Surf is the same year and model of yours. I am currently diagnosing glow plug issues with mine. If the engine is warm at all the glow plugs only come on for a fraction of second. Cold they are on for 20 or more seconds. Which is completely normal ( i think). The dash glow plug light seems to work independently of the glow plugs actually having voltage, always 2 or 3 seconds on hot or cold so i think i am going to install a light from the wire that goes to the rail. I installed new glow plugs last winter and I think i may have one or to faulty ones now as cold starting is horrible. When its warm it fires right up and purrs like a kitten. I would be glad to compare tests and assist you where I can.
            Glow plugs.
            On my old Surf I used to ignore the light and listen for the relay to click off. Learned that on my old Escort van, don't rely on the light!
              Now that's sound advice, ignore the dash-light, sit and listen for the relay, the sound seems to come from the passenger foot-well. arh
