or anyone else with any ideas or imput,
Hi matt, hope you dont mind me asking a lot of what you might think of as daft questions, not sure where to start but i'll explain what i'm doing and what i'd like to happen and take it from there,
I'll soon be fitting the coolant fans, four in total, two mounted in front of the original rad (one original and another i got from ebay) and two (AC fans) fitted above the second rad, underneath, i would like them all to come on at the same time, and idealy run on after the ign has been turned off, i've got the drawing you did but the more i look at it the more confused i get,
would i be better off forgetting the original harness wireing and starting from scratch? (but still be able to use the corolla sensor switch), any help/advice would be much apprecieated, thers no big rush as i aint fitted the fans yet and i'm back and forth to the hospital this week and i know your busy,
i'm still running the viscious fan BTW, the above 's all back up,
Cheers Ian
Cheers Ian
