OK! first thanks Alekseyev for the comment, much apprecieated
Matt, i got the lower fans fitted now and a bunch of four cables in the bay ready (the ones hanging over the wing) been looking on veh wireing and what relays do suggest, i thought of either fitting four R20 B's 30amp to work each fan or two
R70's 70amp to work two fans each, wotch reccon? also anything else i need to buy, i have plenty of switches, led's etc, looking at your drawing is the parts marked n/c and com the relays? and the top right hand side of the drawing is cut off, i take it that reads permanant feeds? no rush, i've shot me bolt moneywise so untill next little job
Vince!!! thought might like to see where your fans ended up, (well actually one of em,) i used one of yours and one of mine, both five blades, also had to cut the shroud down for it to fit, fired em up and all ok
Also got the sensor switch in after a struggle, some **** has got hammerite in the thread,
Feel safer now the front bars are back on, summat to hold on to should the scoop try and suck me in
http://www.vehicle-wiring-products.e...ays/relays.php
