The main benefit of the standard V6 is that surfs with them in are very cheap and a little bit faster than the diesel ones. That's about it. Main problem is that they like to blow head gaskets and are a perfect combination of thirsty and slow.
I believe, although I may be wrong, that your best bet for a replacement would be a Supra twin turbo engine. Have a look here:
http://www.supracharged.com/index.shtml
If I was going to put a diesel engine in, I'd go for the 3.0, not the 2.4. Probably about the same amount of nightmare but you would be overtake tractors.
