Mind if you're stuck with the electrics I am available.
Lexurf IV - The Second Coming
Very bright! I'll give it a chance to get myself used to them, if they still seem bright after a couple of weeks, I'll dim them down.
I used those strips, rather than individual LEDs, for the auxiliary gauges.Do you know that, with a 50 character limit, it's
I can tell, I did say they were too bright.Originally posted by Albannach View Post
I used single 5mm LEDs pointing at the top centre of each auxillary gauge.
As the needles move towards the centre, they get brighter. Handy for the temp gauge at least.
Are the white dial faces backlit?
It's running... It keeps getting soaked and drops the back 2-4 cylinders. There's lots of wee fiddly jobs to do on it, I'll work through them when I get the time.Originally posted by yoshie View PostIs it running properly now Andy? Are you far away from getting it back on the road?
No idea when it'll get back on the road, Insurance is becoming an issue and nobody locally will MOT it because the V5 says it's a 2.4 and the Kerb weights are wrong. So, some admin work to do too.Do you know that, with a 50 character limit, it's
Originally posted by Albannach View PostIt's running... It keeps getting soaked and drops the back 2-4 cylinders.
Is that due to the bonnet vents?
WTF??? A vehicle is tested for what it is not what a piece of paper says it is!
Yep, I've covered them, but some water still gets in. I'll seal them up completely at the weekend.Originally posted by BUSHWHACKER View PostIs that due to the bonnet vents?
The truck doesn't show up on the (private) VoSA database, so it starts alarm bells ringing. They say the new rules say that if it's not on the database, they can't do it. It's in at another place tonight, will see how it goes.Originally posted by BUSHWHACKER View PostWTF??? A vehicle is tested for what it is not what a piece of paper says it is!
The database error is causing issues with some of the insurance companies; one has even suggested that it's 'probably been cloned'.Do you know that, with a 50 character limit, it's
I didn't have a problem when I MOT'd it.
Registration and chassis numbers is all my tester needed.
Even when pulled over by Sussex traffic cops on the way to Graham's the day after (it flagged up on their VNPR as having no MOT) I just showed them the certificate and no other questions asked, so I guess it does exist on VOSA's data base.
Can't help but wonder if the trouble you're having is to do with this...
http://www.the-ace.org.uk/armageddon/
KS said the new rules that came out this year state that if it's not on the computer it can't be tested.Originally posted by BUSHWHACKER View PostCan't help but wonder if the trouble you're having is to do with this...
http://www.the-ace.org.uk/armageddon/Do you know that, with a 50 character limit, it's
Originally posted by Albannach View PostKS said the new rules that came out this year state that if it's not on the computer it can't be tested.
KS?
In that case, how come Lexurf II has just got a new MOT? It's chassis number doesn't match the number on the VIN plate.
I found that out when I took it for it's MOT two years ago. I got the MOT using the chassis number behind the driver's side front wheel.
