'A' Turbo? Surely vince could squeeze one per bank in there? its all about useable power though, and i don't think the on/off of turbos would suit the surf's laid back style unless you tightened everything up a lot! Big cubes smoothly fed in sounds nicer to me. 280 hp will probably sound even nicer rattling out a custom exhaust job.
www.johnthebuilder.info
Will see if a turbo is feasable at a later date, maybe a supercharger would save you the polishing Vince!
Absolutely no room for a turbo, not if you want to off-road the truck anyway.
A supercharger would fit no problem.
Been searching ebay for a while for an m90 supercharger kit or even just the adaptor plate for the 1uzfe, has anyone seen them up there? or would I have to "bite the bullet" so to speak.
Also can you get away with a piggyback ECU? looking for an output of 400hp+ eventually. So many questions....
As you say its worth running it round for a while first before going for something like that though.
