Lexurf IX......
Originally posted by Albannach View PostWhat did you use on the wee needles?
Individual red 5mm LEDs, set into holes drilled in the back of the housing and aimed at the back of the small needles. They will get slightly brighter as they get to the halfway mark on the gauge.
I painted the needles with red flourescent model paint too.
I thought about using THESE. Stick them to the gauges underneath the needles.Originally posted by BUSHWHACKER View PostIndividual red 5mm LEDs, set into holes drilled in the back of the housing and aimed at the back of the small needles. They will get slightly brighter as they get to the halfway mark on the gauge.
I painted the needles with red flourescent model paint too.Do you know that, with a 50 character limit, it's
The picture shows long strips, but there are wee 5cm strips with only 3 LEDs. I'll play around with what I've got though, what's the worst that can happen!Originally posted by BUSHWHACKER View PostI tried using LED strips like those but they gave out too much light. I even cut them down to just four LEDs but they were still too much.
I fitted the single LEDs from the back and just poked then through the drilled holes slightly and secured them with hot melt glue.Do you know that, with a 50 character limit, it's
Flexplate removed and shiny new flywheel and spigot bearing fitted....
New heavy duty Exedy clutch fitted......
Refurbished Surf clutch fork and clutch release bearing fitted together with new, V8 to Surf manual gearbox bellhousing........
Gearbox and transfercase all bolted to the back of the engine.....
All ready to chuck in the 'hole'......
I'm more concerned about the bloke dangling from the rafters...Originally posted by muddle View Postooo shiney.
vince, is that a stolen bike in the pic your'e concealing under a dust sheet?"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
I didn't expect that
