Here's the oil filter relocation kit fitted to the block....
Driver's side engine mount...
Corner cut off resonator box on the intake...(Yes I know I've sealed it with gaffer tape, but it's coming off soon to be replaced by polished stainless ducting)
Radiator clearance...
Sump/relay rod clearance...
Showing handbrake pulley assembly re-mounted the other side of the bulkhead...
Hope that helps.
Hope that helps.
